Latest post 02-26-2008 2:30 PM by Stan. 13 replies.
Page 1 of 1 (14 items)
  • 02-23-2008 3:27 PM
    Wireless B&O
    Can I go wireless with B&O? Or do you advise a different route?
    I like to have ML music in the kitchen.
    My first thought is to buy a (second life) Beolab 2000 and hook it up to Beolink Wireless.
  • 02-23-2008 4:05 PM In reply to
    Re: Wireless B&O
    I could be wrong but I believe for it to be wireless it has to have a powerlink connection.  I think the newer BL3500 have the powerlink connection butI don't think the BL 2000 does since it has been discontinued.
    Roger
  • 02-23-2008 5:31 PM In reply to
    Re: Wireless B&O
    R Patton:
    Roger
    If I'm correct the Beolink Wireless is updated. So it can be connected to ML. But I can be wrong.
    Either way. If the BL2000 isn't an option, can you suggest what to use as an alternative (B&O style)?
  • 02-24-2008 12:44 PM In reply to
    Re: Wireless B&O
    Any product with an ML connection can be used with BL Wireless now.
  • 02-24-2008 1:04 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: Wireless B&O
    The Stig - ver. 1.5:
    Are you sure?  The wireless manual (on bang-olfusen.com) only shows speakers being connected to the powerlink sockets.  It also shows that the ML connection is for the transmit end.  I guess it doesn't say the ML connection cannot be used on the receive side, but this is my impression from early posts on this site.  Also, they added a powerlink socket to the BL3500 so it would work with the wireless (from the technical specs):
    "We have also updated the BeoLab 3500 speaker, giving it a Power Link socket, which makes it compatible with BeoLink Wireless 1. BeoLab 3500 is now compatible with the new BeoLink Wireless 1."
    It would be nice if the ML worked on the receive side, but I'm not convinced...
    Stan
  • 02-24-2008 1:15 PM In reply to
    Re: Wireless B&O
    Yes with the new SW for BL Wireless all thats need is a ML Cable in the receiver end to. Yes BL3500 has a PL socket for use with BL wireless and a IR EYE. BL 2000 don't need the eye
  • 02-24-2008 1:23 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Re: Wireless B&O
    Yes with the new SW for BL Wireless all thats need is a ML Cable in the receiver end to. Yes BL3500 has a PL socket for use with BL wireless but it's not need anymore.
     So does this mean that you can put a BeoPort, BeoActive or BeoPassive at the receive end?
    Thanks,
    Stan
  • 02-24-2008 1:36 PM In reply to
    Re: Wireless B&O
    Beoport Not possible. BL wireless is (can work as) an BLActive, and BLPassive can be connected with PL or ML (for Mcl use)
  • 02-24-2008 2:00 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Re: Wireless B&O
    Yeah, I figured BeoPort was too much, but I'm interested in connecting a Wireless to BeoActive to switch my BL speakers between link sourced audio and local, non-B&O audio via the PC-in port (that doesn't seem to exist on the wireless).  Any clue on this?
    Thanks again, this is very helpful information you have supplied.
    Stan
  • 02-24-2008 2:34 PM In reply to
    Re: Wireless B&O
    Yes it's also possible to connect BL active to BL wireless
  • 02-24-2008 2:35 PM In reply to
    Re: Wireless B&O
    +: Supported
    - : Not supported
    Product (audio)
    Wireless 1 as transmitter
    Wireless 1 as receiver
    BeoMedia 1 MK III
    + [1]
    BeoCenter 2, Audio Only
    BeoCenter 2 MK II
    BeoSound 4
    BeoSound 3200
    BeoSound 9000 MK III
    BeoPort
    BeoLab 3500 MK II
    + [2]
    BeoLink Active
    BeoLink Passive
    BeoSound 1
    BeoSound 2
    BeoSound 3
    BeoCenter 2 MK I
    BeoSound 3000
    BeoSound 9000 MK I MK II
    BeoSound Ouverture/4000
    BeoLab 2000
    BeoLink PC Office
    BeoLab 3500/LCS9000
    BeoSound Century/2000
    X-tra speaker kit
    BeoCenter 2500/BeoCenter 2300
    BeoCenter 9300
    BeoSystem 7000
    BeoCenter 2300 (Beo4)
    [1] BeoMedia as Audio Master, must be connected to a Video Master
    [2 Only via Master Link plug on BeoLab 3500 MK II
    Product (video)
    BeoVision 9
    BeoVision 9 US (no system mod.)
    BeoSystem 3
    BeoSystem 3 US (no system mod.)
    BeoVision 7 - 32/40 (A1)
    BeoVision 7 - 32/40 EU (B6)
    BeoVision 8 - 26/32
    + [1]
    + [1]
    BeoCenter 6 - 23/26
    + [1]
    + [1]
    BeoVision 6 - 22/26
    BeoVision MX 4200 (B3)
    BeoCenter 1 (B3)
    BeoVision 1 (B3)
    BeoVision MX 8000 (B3)
    BeoVision 3 - 28 (B3)
    BeoVision Avant DVD 32 (S2)
    BeoVision 5 EU (S2)
    BeoVision 5 US
    BeoVision 3 - 32 (S2)
    BeoSystem 1 EU (S2)
    BeoSystem 1 US
    BeoSystem 2 EU (S2)
    BeoVision 1-Link (B2)
    BeoCenter 1 (B2)
    BeoVision 1 (B2)
    BeoVision 1 (B0)
    BeoVision 1 (99)
    BeoVision 1-LS (B0)
    BeoCenter 1 (B0)
    BeoVision 3 - 32 (S1)
    BeoVision Avant US
    BeoVision Avant RF CTV (S1)
    BeoVision Avant CTV (S1)
    BeoVision Avant DVD 28/32 (S1)
    BeoVision Avant RF
    BeoVision Avant Slutdisp.
    BeoVision Avant 99
    BeoVision Avant 98
    BeoVision Avant 97
    BeoVision Avant 50Hz
    BeoVision AV 5 (old SAT)
    BeoVision AV 5 (99)
    BeoVision AV 9000 IT
    BeoVision AV 9000 Beo4
    BeoVision AV 9000 2 way
    BeoVision MS 6000 IT, NT
    BeoVision MS 6000
    BeoVision MX 6000/7000, 4000 - NT, IT, Beo4
    BeoVision MX 4002 NT, IT
    [1] TV must be equipped with a module providing a Master Link Interface
    Product (speakers)
    BeoLab 5
    BeoLab 7-1
    BeoLab 7-2
    BeoLab 7-4 (mono)
    BeoLab 4
    BeoLab 9
    BeoLab 3
    BeoLab 2
    BeoLab 8000
    BeoLab 6000
    BeoLab 4000
    Earphone A8
    Form 2
    P10 (P12 headset)
    BeoLab 4 PC
    BeoVox CX 100
    BeoVox CX 50
    BeoLine RL 6000
    BeoLab 2500
    Form 1
    BeoLab 1
    BeoLab Penta MK III
    BeoLab Penta MK II
    BeoLab Penta MK I
    BeoLab 4500
  • 02-24-2008 4:21 PM In reply to
    Re: Wireless B&O
    Thanks for the list.
    Made it a post on the blog section for easy access.
    Filed under:
  • 02-26-2008 12:37 PM In reply to
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Re: Wireless B&O
    What is the sound quality using Wireless like? My dealer told me that since i had a couple of wireless network APs around my apartment I could pretty much forget about the whole thing and use cables instead. The problem is that my landlord probably would chop my head off if he caught me drilling a hole in his floor. Erm
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
  • 02-26-2008 2:30 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Re: Wireless B&O
    My dealer told me that it sounds great and most of his customers love it and have no problem with interference from a WiFi network and/or Beocoms (just don't put any of the equipment too near the microwave oven).  On the other hand, when the wireless was first introduced, there was much complaining on this forum about problems with interference.
    My cynical side says "of course the dealer is going to say all is well - he wants to sell me something".  Then again, I'm in the US where we mostly build our homes from sticks and paper and, in my area, not densly populated.  If I recall correctly, most (if not all) of the complaints on these forums were from folks living in densely populated areas and/or with thick concrete/stone/metal walls.
    Personally, if a dealer tells me not to buy something, I would listen.
    Stan
