Latest post 02-22-2008 6:36 PM by anampersand. 5 replies.
Page 1 of 1 (6 items)
  • 02-21-2008 10:22 PM
    Beogram 5500, Fine Tuning?
    Guess what?!  I JUST completed my Beosystem 5500.  Got my Beogram 5500 turntable tonight, and have been playing the Neutral Milk Hotel record (fantastic sounding on vinyl, if you haven't heard it).
     Anyway, messing around with the MCP, I hit Step Forward and it steps a few minutes ahead, but I'm finding it very troublesome to start a song at it's beginning.  Is there a way to do this with these tangential tables, that is, to start a song at the beginning, like how you'd place the tone arm on a radial table?
     It plays wonderfully, the MMC-2 sounds fantastic, and I have NO gripes on this -- I'm just wondering how to enjoy it right!  I've never had a tangential table, and I have no clue how to do the whole "remote-changes-the-track-thing" on a turntable.
    Can anyone fill me in?
    Thanks again!
    -Aaron
  • 02-22-2008 2:37 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beogram 5500, Fine Tuning?
    Press stop then use the << >> button to track to where you want then press play.
    To be honest the track skip function on these decks isn't very good. You may as well use the buttons on the deck as you'd need to be close to the record to see the set down point in any case.
    Chris.
  • 02-22-2008 2:43 AM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    The short answer is .... No!
    The Control of the tangential arm from the MCP is just as you've found.
  • 02-22-2008 2:36 PM In reply to
    Medogsfat:
    This is something I've been thinking about. If the vinyl had prevailed until now, it would be so easy to make a real track search function. Fit a small CCD camera in the detector arm, and it wouldn't be too hard to "see" the smooth sections between the tracks... and this would've been very much like the usual gimmicks B&O has been known to implement!
    -mika
    -mika
  • 02-22-2008 2:58 PM In reply to
    • Medogsfat
    • Posts 4,045
    I had a Kenwood system with a tangental deck some years back which was supposed to track the smooth sections of the vinyl to skip tracks but it never really worked properly as it saw parts of tracks where the recording levels were quite subtle.
    It was quite a nice system actually (top of the range at the time) until I lent it to my teenage nephew for a party, hence the onset of my beobug when I sought a replacement system so in the end it all worked out well.Smile
    Chris.
  • 02-22-2008 6:36 PM In reply to
    Thanks guys.  I swore I was missing something easy with using that remote.
    But you're right: it's more convenient anyway just to control it from the deck.
    Thanks again!
