Latest post 02-21-2008 8:54 AM by Morgan. 5 replies.
Page 1 of 1 (6 items)
  • 02-21-2008 4:42 AM
    AV9000 master link
    I would like to know if it is possible to conect an AV9000 as slaved to a BV7. The AV9000 was designed as the center of a system. Is it possible to conect as secundary and watch DVDs from a BV7??? How is it possible? I think the master link of them are different. Any idea?
    Thanks in advance.
    Rafa
  • 02-21-2008 6:19 AM In reply to
    Re: AV9000 master link
    Unfortunately, it is not possible to set the AV9000 as a slave. I am sure there is a way to use the DVD player in the BV7 but it doesn't seem likely to be via ML.
  • 02-21-2008 6:25 AM In reply to
    Peter :
    Any idea about how to do this?
    Thanks Peter.
    Rafa
  • 02-21-2008 8:02 AM In reply to
    Long SCART lead possibly? I must confess that I just bought a separate DVD player for my AV9000 and use a DVD-C to operate it. It also is a DVD recorder and Freeview box so I get a lot of extra functions.
  • 02-21-2008 8:31 AM In reply to
    Same as long scart lead why not get a scart adaptor (x2) similar to the types used in PS2s and Xboxes and then run long composite cables along. Much more flexible than a thick scart cable.
  • 02-21-2008 8:54 AM In reply to
    Could be BeoLink Active an option, and have the system with BeoVision 7 as master and AV9000 as slave?
    Rafa
