Hi Keith,
Thanks for the quick reply.
Actually, the distance between the base from each repeaters isn't that far. The base and the tramsitter is located at the G/F. Then there is square looking repeater in the kitchen, 1 in the study room which should also cover the master bedroom area too. 1 repeater located upstair. below is what I think the distance should be.
- FYI, I live in HK, G/F is 200 s.m. and upstair is 120 s.m.
- Base unit is fairly close to the staircase and to the repeater upstair ( base > upstair repeater = 5 meters MAX)
- Base unit from the kitchen repeater is 15 meters MAX, there is a cord wall in between. And if I go further down to the maid's room, possibly the line could get cut off. The kitchen repeater is located in centre of the kitchen and the maid's room. In fact, at once I was standing right in front of the kitchen repeater and the line still got cut off, whereas I can still see the red light is on from the repeater.......
- Base unit from the study room repeater is also around 15-20 meters, in between that, there is only some full height cabinets, no cord wall or whatsoever. And the distance between the study room repeater to master bedroom phone unit is only around 6 to 7 meters.
As said, I do have the old beocom 6000 which was a stand alone unit at the study room, and if I take the phone and walk to living room, kitchen....singal is still pretty good, so I'm a but surprise that the new one can't plus all these add on repeaters.....!!!
I do have Wi Fi all round for both downstair and upstair, AV eqpts......etc...etc. But as said, it doesn't affect the old beocom, and why should it interfer with the new system, am I correct ?
Thanks you so much for the help......
Fc
PS: Btw, are there any way that I can get the old repeater ? Coz some ppls did say they actually work much better then the new one......for some reason I don't know why...
