Latest post 02-21-2008 1:28 PM by Fil. 3 replies.
Page 1 of 1 (4 items)
  • 02-20-2008 10:23 PM
    Help with Avant (US)
    I've managed to accidentally put my Avant into Record Lock. Help! How do I turn Record Lock off?
    TIA
  • 02-21-2008 9:53 AM In reply to
    Re: Help with Avant (US)
    When you are talking about "put AVANT into Record Lock" are you talking about Record Lock for VCR or Record Lock which with some STB's appear in the Menu on the left hand side of the screen when you press Menu on the Beo4 ?
    Regards Keith....
  • 02-21-2008 10:45 AM In reply to
    Thanks for replying Keith.
    I think it's record lock with VCR. The word "Record" appears on the red LED display on the Avant and I can't do anything such as change source (VCR, TV, STB, VAux, Channel up/dn).
    I decided to unplug the TV and that cleared the issue, but I know there's a better way.
  • 02-21-2008 1:28 PM In reply to
    • Fil
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 90
    It sounds like you pressed the record button and that's it.......can't change it to any other channel/function?
    On my Avant dvd linked to a v8000 the same happens when i press record twice on my beo 4.
    To get out of this mode i select v mem (v tape) depending on your beo4 then the stop button on the remote and it stops!
    Hope that helps?
    Fil
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
