Latest post 04-30-2007 4:57 PM by Beowulf. 2 replies.
Page 1 of 1 (3 items)
  • 04-30-2007 4:34 PM
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Beovox RL140 update
    Collected the speakers yesterday,  I have just dismantled one to inspect the driver surrounds and they appear fine. Does anyone have a wiring diagram or service manual available as I intend to rebuild and upgrade the crossovers.
    Kind regards
    Dave
    Beowulf
  • 04-30-2007 4:48 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Hampshire
    • Posts 433
    Re: Beovox RL140 update
    No sorry no manual - but how easy was it to open  - any tips or difficulties?
    I might just check mine after all these years!
  • 04-30-2007 4:57 PM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Fairly easy, just ensure you have removed every screw, there is one under the mounting plate and two under each strap took only 15 minutes, I want to recover them although the grills aren't too bad.
    Beowulf
