1st March February 2012
Latest post 02-20-2008 11:49 AM by ajames. 4 replies.
02-19-2008 11:26 AM
ajames
- Joined on 05-04-2007
- Posts 275
Don't know if anyone can help with this - I have an MX3500 in my bedroom and an Avant in the living room - I cannot get any sound on my MX when I press Sat or Vtape - pictures come up from the avant but no sound - in the kitchen there's a non b&o TV with a beolink active and the sound comes out of the speakers and also the TV in the kitchen. When tuning I get SYS:G on the mx in the corner - is this correct?, if not does anyone know how to change it to what it should be? Anyhelp much appreciated.
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
The reason that you are not getting audio through the MX3500 is that you have selected the wrong version of PAL in the tuning menu. I seem to recall that there are other options available. Pal I and Pal BG. It is a while since I last tuned one in and I can't remember which one it should be, but if you try changing it to one or the other one will definitely work. Sorry I can't be specific but a bit of trial and error should get the job done. Hope that helps. Opman
ajames
- Posts 275
Thanks for the reply - does anyone else know how I would change the SYSTEM setting to PAL I or BG? - can't seem to find it in the manual.
Opman
- Cheshire, UK
- Posts 323
I have looked up which version of PAL you need and it is PAL I. If you select Sat then unplug the data cable from the back of the MX3500 and go into the tuning menu, from there you can select which PAL you want to use. You have to unplug the data cable so that you don't start tuning the TV in the main room. Remember to plug it back in when you have finished. I have been trying to hunt down an instruction manual but without success. Perhaps someone else can help you further. Opman
ajames
- Posts 275
Thanks again - foudn out it's shift 3 to change the SYS setting - but hadn't thought about unplugging the link cable - thansk for that - will give it a go tonight and hopefully all will be well.
Page 1 of 1 (5 items)
