I have a Beogram 4002 type 5523 US version that I have owned since around 1978.  I've always had to deal with a hum noise that I thought was coming from my pre-amp.  The hum sound, I estimate, is about 60hz and is present in both channels.
I've tried different things to try to isolate it.  Since it makes the noise at idle, with the solenoid to the cartridge open, I don't think it is coming from the cartridge.  After changing preamps I also tried a shorter and heavier guage ground wire.
This model has RCA cables, instead of the DIN, that are of poor quality.  The wire conductor is small and the connectors are low quality and starting to oxidize.
Is this a common problem with these models?  I really want to clean this up so I can make better digital copies of my vinyl.
Any ideas on what to try next?
As you can tell this is my first post.  The one thing that I am a little sensitive about is when people characterize equipment of this era as old.  I bought my 4002 when I was 20.  OK, I guess I am old too, but perhaps people could use terms like vintage or seasoned in the future and by all means avoid the word antique.
