Latest post 02-19-2008 4:02 PM by sajpratty. 11 replies.
Page 1 of 1 (12 items)
  • 02-17-2008 7:32 PM
    Beovox P30's
    I'll never learn - how was I to know nobody else would bid? Anyway, it's not a financial disaster
    Initial inspection shows:
    Woofers - one shows about one ohm resistance and blips when I measure it, the other shows zero ohms and is stony silent when I measure it.
    Tweeters - same story, different cabinets (ie one cab has an iffy woofer, the other has an iffy tweeter.)
    Crossovers - charred wadding around, if the cabs had been vented there would have been some smoke.
    Cosmetics - after a good cleanup and some teak oil, actually rather nice and way too good to give up on.
    My guess is that someone got over enthusiastic with the volume knob in the past. I don't feel inclined to risk an amplifier by plugging these in yet. And I've no complaint about the vendor, who 'fessed up front that the tweeters might be goners too.
    Woofers I'm not so concerned about, I saw Martin had some in stock not so long ago and they're only Philips items that can fall apart anyway. Tweeters I'm a tad more disappointed about, apparently they were nice SEAS items. Crossover capacitors and resistors shouldn't be too much hassle I'd have thought, been there done that.
    So there they are. What I'm wondering is do I need one woofer and one tweeter or play safe with pairs? What sort of resistance should I have seen across the drive units?
    Many thanks in advance,
    Steve
  • 02-18-2008 3:41 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beovox P30's
    Hi Steve,
    These are nice speakers. I love the sound of the P series but they need to be wallmounted to do their best.
    The DC resistance measured across each driver should be lower than the impedance but not a lot. I would expect any beep'er to beep when put across any resistance lower than apprx 10-20 Ohms.
    Put a 10 Ohm resistor (or a known good woofer) in series with a woofer to test it. Put a 22uF bipolar capacitor into the series to test tweeters.
    Drivers are no problem. I have good used woofers and tweeters in stock and I may also have crossovers or components,
  • 02-18-2008 4:17 PM In reply to
    Re: Beovox P30's
    Hi Martin,
    Wallmounting was my intention all along, and I wanted teak to match the rest of my stuff.  Very many thanks, this is sounding most promising. I shall be testing the individual bits out as you advise, though my first inspections tell me I might need the full kit. Too much black crusty stuff on the crossovers to read all the component values, but at least the manual has the circuit diagram for them so I'm not lost.
    I think you can expect a PM before too long Smile
    Steve
  • 02-18-2008 4:27 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beovox P30's
    Very nice speakers, I aquired an absolute mint pair in the original box. When I brought some stuff of Ebay a while back. They sold for over £70 when I listed them properly. Only had a quick play with them, but they sounded great with my BM1000. That was with them on the floor too.
    CraigSmile
  • 02-18-2008 6:17 PM In reply to
    Re: Beovox P30's
    Just out of curiousity: you state the woofers are Philips and tweeters Seas, you're sure about this ?
    Because i had 2 pairs of P45's and all units were Seas, and from the same era S45.2's have Seas woofers and Philips tweeters....
    And they do sounds different !!, so it's not like 'well, whatever we have in stock', but it's funny/interesting to see this mix....:)
    btw, if you keep your volume a bit modest you won't ruin an amp just trying them out, who knows: if you're lucky only the filters are 'grilled' ??:)
  • 02-18-2008 7:01 PM In reply to
    Re: Beovox P30's
    Thanks, I'm looking forward to getting them sorted. I'm planning on having them with a BM1001 - the bedroom stereo. Currently got BV1001's on it but I'm not overly impressed by them so they'll be demoted to ambient duty. Walls are they only places the speakers will fit into that room.
    Cheers, Steve
  • 02-18-2008 7:08 PM In reply to
    Re: Beovox P30's
    ipaul:
    Well, I was just going by what BeoCentral had to say about them
    Fingers crossed on the drive units, but I'm thinking I'll be lucky if I get to keep one tweeter and one woofer. Still, after a 50 pence outlay so far I have plenty of budget to spent before things get silly Smile
    Cheers, Steve
  • 02-19-2008 3:36 AM In reply to
    Re: Beovox P30's
    You could always just buy these and keepthe others for spares....
     P30 on Ebay
    Simon
  • 02-19-2008 8:41 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beovox P30's
    wirralsimon:
    You could always just buy these and keep the others for spares....
     P30 on Ebay
    Simon
    Well you could but you'll be bidding against me and I've put a £6000 opening bid on them - honestEmbarrassed
    Chris.
  • 02-19-2008 3:15 PM In reply to
    Re: Beovox P30's
    Medogsfat:
    wirralsimon:
     P30 on Ebay
    Simon
    Chris.
    Thanks, yes I saw them  but recognised the bidder so decided to pass. Smile
    Lets' hope nobody reads this and bids £5999 Devil
    Cheers, Steve
  • 02-19-2008 3:41 PM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beovox P30's
    sajpratty:
    Medogsfat:
    wirralsimon:
     P30 on Ebay
    Simon
    Chris.
    Cheers, Steve
    LaughingLaughing
    Feel free to bid Steve,
                                    you will have more use of them than me, I'm only speculating at £1 really.
    Chris.
  • 02-19-2008 4:02 PM In reply to
    Re: Beovox P30's
    Medogsfat:
    sajpratty:
    Medogsfat:
    wirralsimon:
     P30 on Ebay
    Simon
    Chris.
    Cheers, Steve
    LaughingLaughing
    Chris.
    Thanks Chris, but now I know that Martin has tweeters and woofers in stock I feel confident I can get my current pair fixed.
    It's true that I'll get use out of them though - currently enjoying Classic FM on a £10 white-key Beomaster 1000 that only needed minor repairs, thru the Beovox  1200's I rebuilt the crossovers for. Sounds lush! Smile
    Cheers, Steve
