I've just purchased a pair of M70's with the original trumpet stands. I've already got a pair of S75's which I plan to replace with the M70's. Would this be a bad idea, I mean how are the M70's compared to the S75's? They haven't been connected yet and I don't know if they are working. First of all the replacement is merely a matter of looks, because I like the trumpet stands better than the square ones on the S75.
How do I open them to take a look inside? I can remove the front cover of the S75, but it doesn't seem to be an option on the M70. Do I have to open the cabinets from the back?
I've been working a bit on the stands, and I can recommend a product calles Autosol to clean the aluminium. It really makes them shine.
