Latest post 02-17-2008 4:13 PM by Craig. 6 replies.
Page 1 of 1 (7 items)
  • 02-16-2008 2:25 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beocord 2000
         Having problems with a Beocord 2000 cassette deck, I purchased it non working. After having a quck look inside, I noticed the large drive belt had stretched. So I ordered a complete set of belts from martin. Just fitted these, but now have a problem. It rewinds and fast forwards no problem. when I prees play though the cassete tries to lift up and it will not play. What does happen is the Left hand spool rotates and just feeds tape in to the cassette case. Any ideas on how to fix this, pretty sure this is something simple.
    CraigSmile
  • 02-16-2008 9:21 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beocord 2000
    Why don't I just send you a replacement cassette unit Craig?
    Means you'll have to take the belts back off though as the one I have has knackered ones as well but saves messing around.
    PM me your address mate.
    Chris.
  • 02-17-2008 8:18 AM In reply to
    • Craig
    • Posts 4,855
    Re: Beocord 2000
    Nice one mate.Wink You have a PM.
    CraigSmile
  • 02-17-2008 10:54 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 2000
    Craig,
    Are you sure you have the belts on correctly ?
    Like this ? (Beocenter 2200 but basically the same deck)
  • 02-17-2008 2:05 PM In reply to
    • Craig
    • Posts 4,855
    Re: Beocord 2000
    Er, they are now.EmbarrassedEmbarrassed Works perfect, going to give it a good test over the next week or so. Just to make sure.
    CraigSmile
  • 02-17-2008 3:49 PM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beocord 2000
    Hmmm,,, does the word Doh! mean anything to you Craig?Big Smile
    Don't worry mate, we've all being there. Now I have a spare cassette unit packed & ready for shipping if anyone needs it.
    Chris.
  • 02-17-2008 4:13 PM In reply to
    • Craig
    • Posts 4,855
    Re: Beocord 2000
    Medogsfat:
    Chris.
    LaughingLaughingLaughingLaughing
    Chris you have a PM.
    CraigSmile
