Latest post 04-30-2007 12:10 AM by beobres. 3 replies.
Page 1 of 1 (4 items)
  • 04-29-2007 10:05 PM
    DVD and BL4000 vs BL4 rears recommendation
    Thanks in advance to all of you who have posted suggestions to my prior posts seeking advice for my home theater set-up.
    Two remaining decisions: DVD player and rears.
     Kit will be BV 4-50 TV, BS3, BL7-2 center, BL6000's fronts.
     Question on rears: Can a pair of BL4's do the job or should I get a pair of BL4000's?  Rears will be ceiling mounted, about 11.5 feet high (3.5 meters) and about 6-9 feet (1.8-2.7meters) behind the main viewing seats.
    Suggestions for DVD player: What players are any of you using with a BeoSystem 3?  I've been considering a Samsung BD-P1200 blu-ray, which I am told works perfectly with the system and Beo4 remote.  Is a blu-ray dvd player overkill for the 720p TV?  Would I be better off with just an upscaling DVD player?  I would prefer a player that integrates with the Beo4 remote-- which is why I'm not considering the PlayStation 3.
     Thanks-- as always-- for your input.
    Todd
    Filed under: , ,
  • 04-29-2007 10:12 PM In reply to
    • Corvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Australia
    • Posts 124
    Re: DVD and BL4000 vs BL4 rears recommendation
    Have you considered the Beocenter 2 as your DVD player. I am using this with the Beosystem 3 and it is fantastic.
     You also do not require an upscaling DVD player if you are going through the BS3 as it will do all the upscalling for you.
  • 04-29-2007 10:24 PM In reply to
    I would do BC2 as well, because I like the design and it should do just fine for DVD watching. Unless you are planning to buy blueray movies I would not yet buy a player, there should be plenty of improvements coming in future models. Would be a cheaper option though.
    Are there any other non B&O DVD players that the BS3 supports?
    JK
  • 04-30-2007 12:10 AM In reply to
    Thanks Corvin & jk.  I agree the BC2 is fantastic, but I'm WAY over budget on this system.  I'm more in the area of a  non-B&O dvd player-- at least for now.  Several Panasonic, Denon, Samsung and Sony dvd players are supported-- I'm curious if anyone has a particular model they have been very happy with.  Thanks~~~
