Latest post 06-03-2008 4:44 AM by Stonk. 14 replies.
Page 1 of 1 (15 items)
  • 02-11-2008 7:31 AM
    beogram 3000-2 tuning slide
    I need the front of a tuning slide for my 3000-2.  They are parts 33, 34, 35 on the service manual diagram - 3302119, 3190026,3302110
    The back and the wheels are present but not the front slide.
    In addition, moving the slide does not tune the FM stations but I will not know why untill I have it apart.
    I think that there should be a cover for the preset tunning that I should also like - part 52 - 3164052.
    Where can I purchase spares for the machine, please?
  • 02-11-2008 10:03 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: beogram 3000-2 tuning slide
    I have an old 3000-2 that's beyond repair. You are welcome to have the missing sliders if they are still attached - I'll have to check. I'm going away in a few days so if you don't hear from me drop me a PM & I'll pick up on it when I get back.
    Where are you?
    Steve
    If you think nobody cares, try missing a couple of payments.
  • 02-13-2008 8:07 AM In reply to
    Steve,
    thank you for your help.  I have sent you a PM.
    Regards,
     Peter
  • 05-20-2008 11:28 PM In reply to
    I still need the parts for my amplifier-tuner as Steve has been unable to help.
     Does anyone have a Beogram 3000-2 that does not work but is complete that they would be prepared to sell, please?
  • 05-21-2008 9:15 AM In reply to
    i may be able to help.
    i will be starting a 3000 resto shortly that will include replacement of some of the slides from a broken 4400. i will chk your listed part numbers against my manuals, but i *believe* they are identical...
    i'll let you know what i find / can part with.
    are you in the states?
    ++++edit++++
    my 3000 and 4400 are in different locales. the 3000 is next to me -the tuning slide does appear to be similar, though from memory -the 4400 tuning slide that i may be able to offer seems "thicker." btw, the manuals do show them as slightly different...
    i'll let you know when i have them together what is viable...
    ++++edit++++
    • B&o bottle opener
  • 05-21-2008 10:19 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Peter, apologies. I did dig the unit out and put it aside as another job to do but alas it's still in my todo pile!  Will will take it apart and send you the bits FOC. I'll try to do it tonight or at least this week.
    Steve
  • 05-21-2008 10:28 AM In reply to
    well...
    hope you two work it out -as the more i look at the 3000, the less likely i thk that the 4400 slide would work for you. the tuning bar seems much thicker on the 3000.
    w/ regards to my project -i am in the unfortunate situation where the slides that i need for my 3000 are the non-wheeled ones (vol/treb/bass/bal) and i have to mod the 4400's to fit in two different planes. (make that three planes -if the thk is indeed different! uggh!)
    wish stonk was in the states -as i could use the slides that peter doesn't need... lol
    oh well, good luck! and let us know how it works out!
    • B&o bottle opener
  • 05-21-2008 2:09 PM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Burantek, I now have removed the tuning slider for Peter & will post it to him tomorrow. Now I have it in bits you are welcome to have the remaining ones  - balance, treble and bass. The volume slider is missing the front but I will include what remains in case it's useful for your project. PM me your address & I'll put it in tomorrows post. Don't worry about postage costs to the US - there's very little weight.
    Peter, the transparent plastic cover for the presets is no longer available and very hard to find even on good beomasters. This was discussed on the old Beoworld site and somebody made one from parts of a clear CD jewel case if I recall. Not sure how but the pictures looked good.
    Regards,
    SteveSmile
  • 05-21-2008 2:19 PM In reply to
    oh my goodness!
    what a generous offer!
    ...now i know why i renewed my membership -what a great bunch of folks!
    if i can ever return the favor (to anyone) just shout!
    a million thanks!
    • B&o bottle opener
  • 05-21-2008 2:35 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Aint Beoworlders great!
    Poor me, never win owt!
  • 05-25-2008 5:51 AM In reply to
    Steve and Jeff,
     thank you both very much for the kind offers.
    I look forward to receiving the tuning slide so that I can finish my project!
     Best regards,
    Peter
  • 05-25-2008 1:51 PM In reply to
    You may wel find you have a problem with the flexible circuit board at the back of the tuning presets.
    The copper tracks develop micro-breaks and this stops the tuning diodes from getting the necessary bias voltage.
    If it hasn't got this fault yet, its likely that when you poke around in there and flex the pcb this fault will develop.
    All you need to do it to find both ends of each track and bypass them by connecting the ends together with a piece of insulated flexible wire - instrument wire is fine.
    I would bet a few of this series have been trown away because people didn't know how to sort this problem out, its pretty easy to do but quite fiddly.
  • 05-25-2008 1:52 PM In reply to
    Ooops, I was meaning the Beomaster 3000-2 not the turntable.
  • 06-02-2008 11:45 AM In reply to
    hi all,
    a quick note to let you all know stonk's parts arrived today.
    as soon as i get time, i hope to have them installed!
    again, thx to stonk and everyone else!
    sincerely,
    • B&o bottle opener
  • 06-03-2008 4:44 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Hi Jeff,
    Glad you got them & thanks for confirming they arrived safely. Good luck with your project.
    Peter, did you get yours? I can only assume not as I've not heard otherwiseSad
