Latest post 02-21-2008 10:15 AM by GuyHui . 14 replies.
Page 1 of 1 (15 items)
  • 02-11-2008 3:48 AM
    • Ken
    • Not Ranked
    • Joined on 04-17-2007
    • Posts 60
    Service Kit for BeoCom 6000?
    Hi all,
    A few weeks ago i got the information from this Forum that I could buy a Service Kit for BEO4. I did this and have now updatede two very old BEO4 to the latest version for an accepatble price.
    I was thinkg off doing the same with some very old (10 yesrs) BeoCom 6000 that I have (one is nok working and the other have some problems). Do someone know if there are a Service Kit abealible for Becom 6000 (old version) and what the price is?
    Regards,
    Ken
  • 02-11-2008 3:59 AM In reply to
    Re: Service Kit for BeoCom 6000?
    Ken,
    The details of the kit you are talking about for the Beocom 6000 are HERE
    Regards Keith....
  • 02-11-2008 5:00 AM In reply to
    • Ken
    • Not Ranked
    • Posts 60
    Hi Keith,
    Thanks for the info. It looks like you are getting all parts of the phone. What do you not get and have to carry forward from your old phone?
    Ken
  • 02-11-2008 5:10 AM In reply to
    Ken,
    You are correct and that is why frankly it is a good deal if a user has a Mark I Beocom 6000 and wants a Mark II.
    So, you DON'T get the following:-
    • Microphone
    • Speaker
    • Battery
    • Back Cover including battery cover
    • Any screws, you use the originals
    You DO get
    • A new front cover and keypad
    • One black & one white connector for keypad to circuit board connection
    • New Display to allow for lowercase characters
    • The main printed circuit board
    Regards Keith....
  • 02-11-2008 5:29 AM In reply to
    • Ken
    • Not Ranked
    • Posts 60
    Hi Keith,
    Thanks again. Just talkt with my dealer, and he told me that they are not allowed to oder this from B&O, as all phone repair is handled by one company. This is for Denmark, could be that the set-up are differeny in other countries.
    Do you know where in U.K. I could oeder thise service kit from?
    Ken
  • 02-11-2008 5:59 AM In reply to
    You have a PM Ken...
    Regards Keith....
  • 02-11-2008 11:57 AM In reply to
    • JC
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Keith Saunders:
    Hi Keith,
        I was hoping to repair a couple of mine. Are they available in the UK?
        Jonnie
  • 02-19-2008 5:59 PM In reply to
    Before you get the kit you need to make sure you have 2.5 software in your base/pstn otherwise the kit is a waste of time.
  • 02-20-2008 2:52 AM In reply to
    • Ken
    • Not Ranked
    • Posts 60
    How do I check the SW version in the base?
     Ken
  • 02-20-2008 3:58 AM In reply to
    Type 9#9#9*int the phone will then say hs sw version,move the wheel clockwises to say bs sw version then press the ok button thats the one in the middle .the top number should read 2.50 if not the base will need a software update.
  • 02-21-2008 5:05 AM In reply to
    • Ken
    • Not Ranked
    • Posts 60
    I can't get it to list the sw version. if I type 9#9#9* nothing happens (other than the display show what I typed and it will try to call that strange number). I have also tried to do it from the menu, but still can't get it to show the sw versions. What do I do wrong?
    Ken
  • 02-21-2008 5:37 AM In reply to
    Well I will check too the sw version of my BC6000 base.
    I will need to replace the speaker as this one is HS.
    BTW, I have a technical question :
    - Is there two different speakers that manage the sounds linked with the ring-tones and the "bips" made when moving the wheel ?
     In fact I can hear the bip, not the ring-tones.
    Your answer will help me to know precisely which spare parts to buy (not forgeting the cosmetic aspect of the refurbishment of the phone).
    Thanks for your input.
    Guy
    --= "Everything gets done with Patience" =-- --= "Less is More" - Mies Van der Rohe"
    --= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
  • 02-21-2008 5:54 AM In reply to
    Sorry ken that the code for the mrk2 Yours is a mrk1 type 9#9#9*dot button 7 then move the wheel to say bs sw version
  • 02-21-2008 6:08 AM In reply to
    No its only one speaker.But you can't buy it on its own it attached to the back cover so you need to order a Top handset i which ever colour you have.Tony
  • 02-21-2008 10:15 AM In reply to
    blacktony:
    Thanks Tony for your reply. I can see clearly now what needs to be replaced. Sounds strange that I can hear the BI but not the ring tones.
    Anyway, I will plan to get mine refurbished soon.
    Guy
