Latest post 02-10-2008 5:30 PM by Bulgarien. 5 replies.
Page 1 of 1 (6 items)
  • 02-10-2008 8:53 AM
    • Bulgarien
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Denmark, Vest Sjaeland
    • Posts 201
    Inteligent Aluminium or Invisible Display in Aluminum... at last...
    For som years ago i wrote about "the Inteligent Aluminum" Its was  topsecret story I found on the internet (proberly a mistake..)
    (I told about it the old forum,(2005)  but I can not not find the story and the "secret" link!) maybe others have better luck?
     Now, at last,  B&O are ready to use thea avance tecnnology. They have made it together with DTU  http://www.dtu.dk/
    I could bee for the next generation of mobilephones?
    As i say, when I first heard about the idea, then will af phone made of one piece af blank aluminium look great, and I still think its will be a piece of art.
     On danish http://ing.dk/artikel/85452?nyhedsbrev
    Bang & Olufsen a/s has been working with ideas for invisible integration of displays in metal surfaces. Invisible integration of information displays traditionally has been possible by placing displays behind transparent or semitransparent materials such as plastic or glass.
     The wish for an integrated display in a metal surface is often ruled by design and functionality of a product. The integration of displays in metal surfaces requires metal removal in order to clear the area of the display to some extent.
     The idea behind an invisible display in Aluminum concerns the processing of a metal workpiece in such a way that micro cavities are formed from the backside of the workpiece. The micro cavities must not penetrate the metal front side, but an ultra-thin layer of metal is left. It is possible to shine light through this layer.
    By ordering micro cavities in a matrix, different symbols can be obtained by shining light from the backside of the workpiece. When there is no light from the backside, the front surface seems totally untouched. This was achieved by laser ablation with ultra-short pulses
  • 02-10-2008 9:05 AM In reply to
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    Re: Inteligent Aluminium or Invisible Display in Aluminum... at last...
    Apple uses this (or similar) technology already; I have an aluminum iMac with wireless keyboard; there is a LED on the keyboard that is only visible if turned on; when off the surface seems smooth.
    Very nice technology!
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 02-10-2008 9:18 AM In reply to
    Yes Bieele, I confirm. At the beginning, I was trying to spot this green light without success. Then I understood it was made upon the technics of invisible display in aluminium.
    Great piece of design tho', just like it very much Stick out tongue
    Guy
    --= "Everything gets done with Patience" =-- --= "Less is More" - Mies Van der Rohe"
    --= BV10 46", BL8K, BL4K, BL2, BS Ouverture, BC6000 (Mk3), BT1100, Beo4 , A8 and ...the Atomic Floyd "Airjax+Mic" earphones =--
  • 02-10-2008 10:15 AM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    The macBook Pros have the same feature. The light next to my iSight camera shines right through the aluminium. It would be nice to see a useful integration of the technology...
     Weekly top artists:
  • 02-10-2008 11:00 AM In reply to
    Similar technology is used by Aston Martin to hide the warning lights.
  • 02-10-2008 5:30 PM In reply to
    • Bulgarien
    • Posts 201
    B&O have taken patent on it! ...
