Latest post 02-08-2008 6:00 PM by Ben. 4 replies.
Page 1 of 1 (5 items)
  • 02-08-2008 5:23 PM
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    MX4000 Remote Control
    I've just secured a nice MX4000 for a good price, but its got no remote.
    From what I understand, a Beolink 1000 is the best choice for value (or a v / av terminal). Is there any particular version I should look out for to be able to fully control this set?
    Also, on a side note, do the speakers in the MX4000 suffer from foam rot?
    Thanks!
    Filed under:
  • 02-08-2008 5:32 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: MX4000 Remote Control
    Beolink 1000 is ideal, i wouldn't recommend AV terminal.
    Regarding which Beolink, i would use the one with the MENU and LIGHT button.
    Depending on which MX4000 you have, a Beo4 might also be very suitable or even be more suitable,
    as this would also give you more flexibility if you should use other B&O products as well.
    Which type-numer is your MX 4000 ? (4 digits)
  • 02-08-2008 5:42 PM In reply to
    • Ben
    • Taunton, UK
    • Posts 131
    • Silver Member
    Its a type 3323 I believe, so I think its an early one.
    My other equipment is a Beosystem 3000 and 5000, so both systems use their own remotes that aren't compatible with the beolink system.
    I like the idea of a Beo4, but i'm afraid thats going to cost several times more than the TV!
  • 02-08-2008 5:48 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    If i'm correct, that's a PAL version with NICAM stereo.
    Beolink 1000 would indeed be ideal.
  • 02-08-2008 6:00 PM In reply to
    • Ben
    • Taunton, UK
    • Posts 131
    • Silver Member
    Thats right! I'll keep my eye out for one with the Menu and Light buttons,
    Thanks.
