Latest post 04-28-2007 6:13 PM by jk1002. 4 replies.
Page 1 of 1 (5 items)
  • 04-28-2007 2:50 PM
    • Graeme
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Aberdeenshire Scotland
    • Posts 194
    Beolink 2
    Can anyone tell me or were I can find info on beolink 2 and what all you need to be able to stream music from your pc to your BS3000?
    Cheers Graeme
  • 04-28-2007 4:48 PM In reply to
    Re: Beolink 2
    You mean the Beolink PC2 or Beoport. You are a Gold member so go to Products then user and service manuals. I'll add a screen shot of which options to pick then press View Manuals. The user manual is there.
  • 04-28-2007 5:46 PM In reply to
    • Graeme
    • Posts 194
    Re: Beolink 2
    Cheers Peter, is this a wireless system?
    Cheers Graeme
  • 04-28-2007 6:13 PM In reply to
    Re: Beolink 2
    No. Wired.
    Re: Beolink 2
    It is not. It would be connected through ML cable to the Audio Master.
    For wireless some here including myself use the airport express (http://www.apple.com/airportexpress/) which works together with Itunes.
    However you would not be able to use the Beo unless you connect a IR receiver or a Beoport to the PC and have it in line of sight.
    I have 3 of those Airports and did connect an IR module to my Imac. Works OK even though I miss control.  I might add a 2 way remote from Keyspan down the line when they finally introduce the PC/Mac version.
    http://www.keyspan.com/products/TVI200C/
    Ugly solution though.
