Ehlerz:Hi All,
I have a simple question i hope you can help me with. The motorized stands for beovisions has a saftyfeature that prevents them from turning when a person is not activly dooing so by pressing the remote. This is to be sure that a child or somthing is not behind the tele when it turns.
My question is if it is possible to disable this feature anywhere as i have no children and would like my television to turn when using sleeptimer. Currently it does not
Hope anyone can help
Try the following, if you have a BV7;
Start the timer mode in TV mode.
Start the timer mode in RADIO mode 1 minute before TV shutdown.
Stop the timer mode 1 minute later for RADIO and TV.
Our BV7 radio stand is position 5 (centered)
Our BV7 tv stand is position 7.
Edit: Tried this on my own setup. No luck either. Sorry.
It seems there is no workaround to get the tv turning without intervention.
