Help! Got a working motor and replacement looks easy, but which plug to plug drive belt motor back intoo???
Had a Beogram 4004 which no one could fix to advance properly. It would play for about 15 seconds, then would not advance. All other features worked fine. So, recently got another, that just needed a motor.
Removed motors to replace, but when I went to plug the working one in ...surprise. There are two identical 3 prong female that it can plug into. One is nearest to front of turntable, the other about 1/2 inch behind the nearest. The internal belt drive motor fits both. Maybe for different types of motors?? Anyway, I don't want to trial and error, as it might be a 50% chance of working...and a 50% chance of burning something out. I am in a 120v area, and both motors are DC3V, MHN-5P2RDS if that matters.
I'd really like to get one playing. Do you know which to use? I'd really appreciate help.
