Hi guys,
I've just bought a Beomaster 5500 & a Beogram 5005 as my first B&O purchases and was wondering...
Question 1.
Is there any way to control the volume on the actual beomaster unit?? it might sound silly, but I figured that there would a be some controls on the front panel (other tha the power + mute + preset).
It's just that I was silly enough to not buy one that include a remote, and although I will be buying one, I was hoping that I could use it in the meantime.
I guess I'll need to buy one of those beolink 1000's?
Question 2.
What (Cheap! I a pretty broke after buying these) speakers would you recommend between $150 - $300?
I've been looking on ebay and I can get some B&O redlines for that + a few others.
Or should I just stick with something off brand (as I guess it gives more options).
Anyway, thanks for helping a complete B&O newbie! It's a learning experience. I didn't even realise that it use din connections for the speakers until after I bought it, so have just nabbed some of those.
Cheers
Kris
