Latest post 02-06-2008 1:16 PM by Ignace. 0 replies.
Page 1 of 1 (1 items)
  • 02-06-2008 1:16 PM
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Speck SEETHRU for MBP
    Hi all,
    Just received the transparent Speck SEETHRU for my MBP today.
    First impression is that it fits very good and all ports can be accessed without any problem.
    What i don't like very much is the shiny hard-plastic look and feel.
    I chose the transparent version as i'm not too fond about the bright colors that Speck offers.
    For now i'm going to use the cover until I've found another product
    that has the same close fit as the Speck cover.
    But i would like to know if there is a similar product (close fit),
    but which is made from a nicer material,
    perhaps something "soft-touch" (bit like the materials that are used in today's cars)
    Do you know if this exists ?
    My MacBook Pro is a 15,4 inch Core 2 Duo
    Thanks,
    Ignace
