Hi
I bought them from an B&O dealer and they're still under warranty ( 2 or 3 years, right?), but I would be pleasesd if someone tested them with the song I mentioned and an iPod, because I just want to know if it's normal (I don't think so). If it's not normal I will get them to the dealer, but I don't want to go there and hear from them that it's normal. Another thing is, that I read a test in the internet where the tester hears the same thing (distortion of deep bass) and maybe someone else has had the same problem (if so, please tell me!).
Edit: I think I solved the problem, I always had the ipod EQ on "Jazz", now I've put it on "linear" and the problem is gone! Thanks for your support anyway!
