Latest post 02-06-2008 10:55 AM by srywrgnbr. 15 replies.
Page 1 of 1 (16 items)
  • 02-02-2008 12:10 PM
    BeoMaster 6500 Power Supply Issues
    Long time lurker, recent member, first time poster...
    Does anyone have a picture of a Beomaster 6500 healthy power supply?
    I recently purchased a BeoMaster 6500 off of ebay.  Apparently, the previous owner attempted to modify a model 2336 (220v) to be a 110v.  Currently, the device does not work.  I would like to compare a picture of a working power supply.  The modification does not match the service manual (their are additional capacitors on the output side).  When the device is plugged in, the second fuse (on the output side) immediately blows.
    Of course, I realize that even if the power supply issue is fixable, the device may be (and most likely is) irreparably damaged.
    Any assistance would be appreciated.
  • 02-02-2008 12:31 PM In reply to
    Re: BeoMaster 6500 Power Supply Issues
    I don't have a 6500 but I do have a 5500 that I can take apart. If you do a picture of the bit you want, I will do a picture of the same part on the 5500 if that is useful.
  • 02-02-2008 1:10 PM In reply to
    Thank you for the quick response.  I have attached a picture.  I do not have anything to compare it to, so I do not know how "modified" it is.
  • 02-02-2008 1:25 PM In reply to
    This is what the 5500 looks like!
  • 02-02-2008 1:38 PM In reply to
    Perfect!  Thank you!!!
  • 02-02-2008 1:48 PM In reply to
    If you need anything, do feel free to ask!
  • 02-02-2008 1:50 PM In reply to
    Peter,
    Is the picture you provided of a 240V version?
    Thank you,
    Rob
  • 02-02-2008 2:30 PM In reply to
    Yes - type 2332 .
  • 02-02-2008 3:33 PM In reply to
    Probably the BM is still intact. The owner before had modified the power supply in the wrong way... the two coils worked against each other, the direction of one coil is wrong.
    This inducts a high current in the coils and blows the fuse at once, but no current goes to the secondary part. Plus and minus is zero ... Devil
    So, if you change it exactly like Peter's foto, then it should work again Big Smile
  • 02-02-2008 5:03 PM In reply to
    By any chance, do you have a photo of a 110V model?
    Looking at the wiring diagram, the wires on the input side "appear" to be correct (for a 110 model).  However, it looks like someone attempted "clean" the signal from one of the output terminals by running a cap to ground in series with a resistor (all of which I plan to remove).
    -R
  • 02-03-2008 5:25 AM In reply to
    The two "resistors" on the output terminals to the chassis ground are capacitors...Wink
  • 02-03-2008 11:26 AM In reply to
    There are two resistors (one each)  running from the negative terminal to the chassis.  There is a single capacitor between one of the positive outputs to the adjacent negative output.
     According to the stripes the resistors are both:
    65300 (Ohm) with +/- 2% tolerence
    In the picture I submitted earlier, you can see one resistor in series with the cap leaving the negative output (close up attached).  The other resistor is similarly installed on the other negative terminal (no capacitor there), but difficult to see in the picture.
    Not sure where you saw the second capacitor :)
  • 02-04-2008 9:18 PM In reply to
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    Is there a replacement power supply existing? Is the original still available as parts?
    My BM has the usual humming feature relating to power supply aging.
  • 02-04-2008 11:59 PM In reply to
    Hi:
    Let me jump in here re: power supply hum because I have had experience with this on my BC 9500
    This may have nothing to do with power supply aging.
    1) It may be dirty AC current in your house wiring! Try taking this to your neighbour's home or to work. Somewhere far away from your residence to see if it goes away.
    I had a very noisy hum on my 9500 and I even posted to this forum asking for a spare transformer. It turns out when I relocated, the hum went away!
    2) The transformer sits on rubber grommets (or sleeves). These serve as shock absorbers isolating the vibrations caused by the AC induction in the core from resonating in the chassis. It is possible that they have dried out or that the screws holding the transformer is either too loose or tight.
    3) Finally also check voltages in output of the power supply, the filter capacitors and bridge rectifier for normal operation. Compromised components could introduce high loading on transformer causing it to hum.
    B&O used really nice transformers! Unless it has had bad case of over heating, they last!
    Check first before investing in new transformer :)
    Derek
  • 02-05-2008 1:08 AM In reply to
    After a little probing, it appears that the rectifier (D3 on the circuit diagram) is bad.  According to the service manual, the part number is BA423.
     I am having a bit of trouble locating the part.  Does anyone have a suggestion?
  • 02-06-2008 10:55 AM In reply to
    I was looking at the wrong parts list :).  The correct part number is B80 C3700/2200
    I replaced the rectifier.  The fuse still blows as soon as power is supplied.  I unplugged P14 and P15 to isolate this part of the circuit - and still the fuse blows.  Now I just need to find out what is shorting to ground....
