Sorry, but I think BeoPort should be set to option 0 (because no IR eye is connected to it), so all controls will come from BeoSound 4.
Indeed all speaker connections should be made on BS4 , if you decide to use BeoPort in another room, then you can always buy a longer Masterlink cable and have a second room with B&O sound through your BeoPort!
Reunion Island is greeting you!
