In the manual the video output of the Beosystem 2 is describe as
RGB-HV / YPbPr out on the 15 pin D-sub
Is RGB-HV and YPbPr the same type or 2 different signal types ?
Does any body know were to find the pin connection for 15 pin D-sub output of the Beosystem 2
I think you will find this is what you are looking for:-
Regards Keith....
