Latest post 01-31-2008 3:50 PM by Medogsfat. 2 replies.
Page 1 of 1 (3 items)
  • 01-31-2008 12:21 PM
    Speaker cables
    I have a Beocentre 7007 with C30/40/75 speakers but I have lost the cables.
    Are these cables available?
    Watkins 31-1-08
  • 01-31-2008 2:48 PM In reply to
    Re: Speaker cables
    Yes, you can either get very neat ones from B&O or make your own. The plugs you need are available from Maplins. If you go for the B&O ones, you need the extension leads, not the speaker leads which only have a male plug at one end and bare wire at the other.
  • 01-31-2008 3:50 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Speaker cables
    Maplin also do ready made leads with 2 Pin DIN plug & socket moulded LINK
    Welcome to beoworldSmile
    Chris.
