Hi Martin,
thanks for helping! How much would it be?
And... about the lamp. I really woulnd't think about a blown lamp (if you refer to the sensor arm's light, it works).
I thought that it could be caused by an electric sensor that "feels" the tonearm's tilt, I couldn't imagine it was optical too
Good to know: I'll tell the B&O technician. I want to bring this BG 8000 to full life as it's a very remarkable piece.
Finally, I'd need a precious opinion from you. Stated that this BG 8000 has been really well packed (it took 15 actual minutes to open the box and unwrap it), it comes from NYC. Can the shipping (via USPS) be the cause of this malfunction, even if so well packed? I need to give a feedback, so...
Thanks a lot Martin!
Luca
