Latest post 02-21-2008 8:28 AM by kevinoils. 1 replies.
Page 1 of 1 (2 items)
  • 01-28-2008 1:27 PM
    Beogram 4000 Tone arm problem
    Hi My Beogram 4000 developed a problem when I was removing the stylus last night, the plastic bracket that holds the stylus came away with the stylus. The little connector had two wires attached a blue and a grean one, but I noticed that there are two inside red and possibly a grey one. Can anyone help with this or does anyone know the best way to take this apart without doing more damage. Help most welcome.
    Kevin
  • 02-21-2008 8:28 AM In reply to
    Re: Beogram 4000 Tone arm problem
    Just a little update
     I managed at last to get the small wires out of the tone arm and then  to feed them through with great patience again. I am attemting to repair the arm on a temporary basis as the mount will be glued but fragile, this seems possible fitting a stylus which will have to remain on until a replacement tone arm for BG4000 is found.
    Kevin
