Latest post 02-06-2008 6:54 AM by warren. 3 replies.
Page 1 of 1 (4 items)
  • 01-28-2008 11:58 AM
    Beosystem 2 STB upgrade
    I am aware that the newer Beosystem 3 supports Apple TV through the PUC but does anyone know if the latest STB controller software in the beosystem 2 supports it?
    Warren
  • 02-05-2008 8:02 AM In reply to
    Re: Beosystem 2 STB upgrade
    Bump... In the hope that someone has an answer?
  • 02-05-2008 2:11 PM In reply to
    You are correct that the "Appleremote" is supported on the Beosystem 3, however the Beosystem 2 uses the latest STB tables 3.90 & 3.91 and I am afraid neither have the "Appleremote"
    Regards Keith....
  • 02-06-2008 6:54 AM In reply to
    Thanks Keith....
    Any idea if the beocentre 6 supports appleremote? If so do you know what software revision I need?
    Warren
