Latest post 02-02-2008 6:38 AM by Keith Saunders. 2 replies.
Page 1 of 1 (3 items)
  • 01-28-2008 6:18 AM
    Beosystem 2
    Is it possible to update a beosystem 2 mk II - to a beosystem 2 mk III (with PC inpust) ???????
  • 02-01-2008 5:08 PM In reply to
    Re: Beosystem 2
    anybody ???
  • 02-02-2008 6:38 AM In reply to
    Re: Beosystem 2
    Well, I have done a bit of research on this one and the following appears to be the situation:-
    • From a software viewpoint, both use the same software and both can be updated to the latest version of 16.2
    • From a hardware standpoint, the Mark III does have the addition of the PC input which would require quite a lot of changes to create a Mark III from a Mark II
    You may find some advantage by having a software update, if your version is a very early one, otherwise I suggest you stay with what you have or do a trade-in if you can, if the PC input feature is important to you.
    Regards Keith....
