Latest post 05-28-2008 3:04 PM by cskytt. 3 replies.
Page 1 of 1 (4 items)
  • 01-27-2008 3:16 PM
    Bevision 3 and PC/Beomedia connection
    I have a Beovision 3 type 8813 with SW 13.3 - in connections I have no PC option do I need to upgrade.  Can the Beovision 3 connect to a Beomedia and how?
  • 01-28-2008 8:33 AM In reply to
    • mosim
    • Not Ranked
    • Joined on 01-23-2008
    • Posts 4
    Re: Bevision 3 and PC/Beomedia connection
    You can connect the Beomedia to one of the scart plugs (Scart to RCA and Phono 3,5mm) and adjust this plug in the connections menu of the BV 3 to V.AUX
    You need the Infrared eye for the Beomedia and you have to change the setup of the Beomedia from PC to V.AUX (When you see the Beomedia Menu on the TV press RED - 9 - GO - 0 - 0 - GO - then go to System Settings and change the command from PC to V.AUX
  • 01-28-2008 12:02 PM In reply to
    Thanks - I will try tomorrow and let you know
    Regards  Terry
  • 05-28-2008 3:04 PM In reply to
    • cskytt
    • Not Ranked
    • Joined on 05-28-2008
    • Posts 1
    Hi
    It seems like I have a problem a like. I have a BV1 that I would like to use as my display for the Beomedia 1. I have connected the Scart cable and an IR eye. I can see the screen on my TV and control N.Music and N.Radio with my Beo4 through my BC2. But the I can not control the disply via BV1, so web and Photo does not work. Can anyone give me some idea on what to do?
    Regards
    Christian
