Latest post 01-30-2008 4:52 PM by kib336. 3 replies.
Page 1 of 1 (4 items)
  • 01-27-2008 2:28 PM
    • kib336
    • Not Ranked
    • Joined on 01-27-2008
    • Posts 2
    Beocom 6000 Memory
    I have a problem with the memory on my Beocom 6000.  The problem is that I had one of my 6000's (no.1) stolen (along with the original base) and the other one I have (no base) (no. 2) has numbers on it that I want to delete.  I had to buy a new 6000 (no.3) with base but when I try to delete the numbers on the original 6000 (no. 2) the message I get is ** NOT BASE 1**
    Can anyone help?
  • 01-27-2008 3:22 PM In reply to
    Re: Beocom 6000 Memory
    You can reset the hand set. Press DOT 70009 OK and it will reset the handset. It will of course wipe all the phone memory.
    Welcome to Beoworld.
  • 01-27-2008 4:23 PM In reply to
    Yes my advice would be to reset your BeoCom 6000 network. From your description, it seems one of your BeoCom's is confused. I doubt this would be a related issue to your particular problem, but do you own a Serene cell phone? These can occasionally mess around with the phonebook on your BeoComs.
  • 01-30-2008 4:52 PM In reply to
    • kib336
    • Not Ranked
    • Posts 2
    Thanks for the help.  That seems to have done the trick!
