Hi All,
A second post on the same subject.
I
have recently aquired above mentioned unit. I still need a couple of
parts, 1. Hinge for the metal cover on the "spring loaded side" as its
worn and the cover slips off. 2. Replacement plastic record deck cover
as the original has snapped all its plastic hinges off at the spring.
Any advice or information on the parts etc would be much appreciated, especialy if you have them and I can purchase them!!
Many thanks,
Boots
