Latest post 01-30-2008 12:47 PM by sveifors. 9 replies.
Page 1 of 1 (10 items)
  • 01-25-2008 12:21 PM
    • sveifors
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North of Norway
    • Posts 145
    Beomaster 1000
    I have recently bought a beomaster 1000. I am wondering about two things about this
    The first since I don`t have a user guide. The BM has two piano -function keys between speaker II and the mono key , which have a sign like            ~ (two of these in parallel). Probably a stupid question, but anyway, What are their function?
    The second is when I play a record player connected in   I get humming sound in the speakers. Do anybody have heard of this problem and is it a sollution to it?
    Sveifors Always look on the B & O side of life
  • 01-25-2008 12:32 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 1000
    The two keys, you describe are filters.
    High-cut and low-cut originally there to remove high frequency "needle-noise" and rumble respectively though they will actually work on any source you play.
    The symbols are indicating two sine waves, where the upper respectively the lower are crossed out.
  • 01-25-2008 4:11 PM In reply to
    Re: Beomaster 1000
    Which record player are you using? It sounds like an earth problem - there should be an earth from the chassis to the casing of the DIN plug.
  • 01-25-2008 5:19 PM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    Re: Beomaster 1000
    I used my beogram 8002
  • 01-25-2008 5:21 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beomaster 1000
    Have you got the Black or White keyed version?
    CraigSmile
  • 01-25-2008 6:44 PM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    Re: Beomaster 1000
  • 01-25-2008 6:45 PM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    Re: Beomaster 1000
    Craig:
    CraigSmile
    Black
  • 01-27-2008 1:00 PM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    Re: Beomaster 1000
    PLEASE Is there anybody who want to help me with this problem. I thought if I had a normal 5 pin cable this should be ok?Do I have to ground it separatly from this cable(extra).
    Is the ground problem in the BM1000 or the beogram?
  • 01-28-2008 10:16 AM In reply to
    Re: Beomaster 1000
    This is difficult one to diagnose so far. I'm guessing that you don't have another Beomaster to check the Beogram with? And that you do not get a humming from the radio? And that there is humming from the record player before the arm is lowered, ie as soon as the gram is "live"? You are correct that the DIN plug from the gram should carry an earth signal already. Peter is almost certainly correct that the humming is caused by a bad earth - somewhere.
    There are two gram sockets on your Beomaster - number one is for grams that already have a pre-amp and number two is for grams that do not. I think I'm right to say your Beogram 8002 does not have a pre-amp built in and that you should be using socket two on the Beomaster.
    You need to hunt down where the problem is - try using a fly lead from the centre pin of a spare socket on the Beomaster to a metal part on the Beogram chassis. If that cuts the humming then that will at least confirm an earth problem. A multimeter set to measure resistance will help narrow the problem down to either the record deck or the amplifier. Chances are most likely that it is the earth connection to the centre pin on the DIN plug of the gram.
    Good luck, Steve
  • 01-30-2008 12:47 PM In reply to
    • sveifors
    • North of Norway
    • Posts 145
    Re: Beomaster 1000
    Thanks Steve I will try to do it like you suggest.
