Latest post 05-01-2007 9:31 AM by Beonut. 11 replies.
Page 1 of 1 (12 items)
  • 04-27-2007 2:20 AM
    Beolab 7.1 vs Beolab 4000's as center channel
    How much better-- if any-- is the BL7.1 as a center channel than a pair of BL4000's?  Does anybody have experience with both/either?  Panel will be a BV4-50 with BL6000 fronts and BL4000 rears.
    Thanks for your input~~
  • 04-27-2007 2:41 AM In reply to
    Re: Beolab 7.1 vs Beolab 4000's as center channel
    beobres:
    Much better.
    My setup is BL7.1 center and BL4000 front speakers
    When I switch between speakers the BL7.1 is preferred. Better bass, better clarity etc. etc.
    [edit: the rear speakers are BL2500 flanking the BS3200]
  • 04-27-2007 2:45 AM In reply to
    Thanks for the quick input, Coolskin.  That's very helpful information.  Are you using 4000's as rears as well?
  • 04-27-2007 5:56 AM In reply to
    • Pushkin
    • Not Ranked
    • Joined on 04-19-2007
    • London
    • Posts 50
    Hi - I swapped a pair of 4000s for a BL7.2 sitting under my BV4-65 - I was surprised by the major improvement in clairity of sound.  Problem now is that as I have decided to go for BL9s as fronts I think that a BL7.4 will be better suited to the center channel.
  • 04-27-2007 6:39 AM In reply to
    • barny
    • Not Ranked
    • Joined on 04-20-2007
    • Posts 12
    As above, BL7.1 is far better. Have tried BL6, BL4 and BL8's as centre just for a laugh. The BL7 is better to my ears than all the above as it is designed as a centre speaker. The closest was the BL8, but it still lacked bass response for the centre sound stage.
    With a 50" screen I'd go with a BL7.2 instead. Wider and more asthetically pleasing.
    Barny
  • 04-27-2007 9:30 AM In reply to
    Thank you all for the input.  clearly it's the BL7's for this set up.  Thanks for the suggerstion on the 7.2's, barney.  I hadn't considered them because I thought they may be too large under the 50".
  • 04-27-2007 9:47 AM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    i don't think the 7-2 would be to large for a 50" screen. would look very good imo
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 04-27-2007 9:50 AM In reply to
    I never really liked the paired 4000's under the plasmas, it looked like it was just pieced together and not an intended use.
    I have a BL 7.2 under my BV4 -50 and inch and it is a perfect match, the 7.1 would have been too small.
    Roger
  • 04-27-2007 1:59 PM In reply to
    • Alex
    • Bath & Cardiff, UK
    • Posts 2,990
    The 7-1 looks fine with a 50" and 65" IMO...
     Weekly top artists:
  • 04-29-2007 9:19 PM In reply to
    • Corvin
    • Top 500 Contributor
    • Australia
    • Posts 124
    OK this poses a dilemma for me as I have just set-up with 2 x BL4000’s, 1 either side of a 50” plasma. I was advised that these should do just as good of a job as the 7.2 would, now I will have to consider an upgrade after 1 month,,, hmmmmm.
    Is the 7.2 really that much better?
  • 04-29-2007 11:53 PM In reply to
    • Pushkin
    • Not Ranked
    • London
    • Posts 50
    Hi - I found the 7.2 to be a significant improvement over the 4000s - well worth the upgrade
  • 05-01-2007 9:31 AM In reply to
    • Beonut
    • Joined on 04-17-2007
    • Essex, UK
    • Posts 89
    I agree with the above I think the 7.1 / 7.2 are both better than the 4000's. I have the bl 7.4 mounted under my bv4-50, I am very pleased with the sound and particularly the look of it, although as it is a mono speaker it is only suitable in a surround sound set up. I have added a picture, although now looking at it it seems it has been stretched in the upload somehow.
    Cheers
    Peter
    My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
