Peter:Go on! Class D are cheap! The reason the BL9 uses Class AB is that it is based on the BL1 chassis which works very well. You simply don't need the high power for the mid range and the tweeter and AB technology is well tried and perfected. It also helps differentiate the BL9 from the BL5.
I would venture that decent quality integrated AB modules are still cheaper than decent quality Class D amps for power ranges of the order of ~50W or so (they are used in Car Stereos and "midi" domestic hifi's by the squillion (not to mention BL8000's).
Class AB modules take an analogue signal and in the same package drive speakers. Class D amps are getting there but I'm not sure they are quite so "off the shelf" at the moment.
