Latest post 04-06-2009 12:28 PM by Dillen. 8 replies.
Page 1 of 1 (9 items)
  • 01-21-2008 4:39 PM
    Problem with Beolab Penta (Beolab 150)
    I've faced a problem: one of Beolab Penta loudspeakers has stoped working!  It seems that the amplifier (which is supposed to be Beolab 150) no longer works: no red/green indication when it is connected to the power point.
    Ideas what it could be and how to repair it?
    Appreciate any help.
    Filed under:
  • 01-22-2008 4:15 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Problem with Beolab Penta (Beolab 150)
    Welcome to Beoworld !
    Maybe your Beolab Penta has blown an internal fuse. There are two fuses located inside, near the transformer in the bottom.
  • 01-22-2008 6:08 AM In reply to
    Thanks for help, it may be the problem actually!
    But I cannot get inside the bottom of speaker (amplifier) -- it seems to be locked from inside.. Is there any instructions how to open it?
  • 01-22-2008 6:44 AM In reply to
    • Dillen
    • Posts 5,008
    I normally do older stuff but I have serviced some Beolab Penta's and if I remember correctly there is a cover held by a single screw in the connector bay.
    Usually, there's a reason for a fuse to blow but I've had more than one case where a fuse was actually the only faulty component in a Beolab Penta. There are two fuses in each speaker, one for the amplifier section and one for the electronics (link control etc.). Make sure you replace with the same type and rating of fuse. In your case, with no light at all, the fuse for the eclectronics would be the most interesting one.
    Of course there can be other causes but checking the fuses would be the place to begin.
  • 02-02-2008 11:57 AM In reply to
    Yeah, exactly : there are two fuses 2A and 40mA and 40mA fuse blown.
    But! Now I cannot find another 40 mA fuse in entire Oslo. The closest I found was 50 mA. Is it OK to use it or should I  keep trying to find exactly 40 mA one?
  • 02-03-2008 8:41 AM In reply to
    • Dillen
    • Posts 5,008
    50mA will be within tolerances, so OK.
  • 02-07-2008 3:43 PM In reply to
    It perfectly works now!
    Thanks a lot!!Smile
  • 04-06-2009 10:13 AM In reply to
    • PeterK
    • Not Ranked
    • Joined on 04-06-2009
    • Posts 1
    Hello
    One of my beolab penta´s just stopped working, no light no nothing. I checked the fuses and the 40amp one was blown, i replaced it and it blew again. What could be the problem and were should i start to look?
    Anyone had a similar problem with there pentas?
    /peter
  • 04-06-2009 12:28 PM In reply to
    • Dillen
    • Posts 5,008
    Hi Peter,
    Welcome to Beoworld !  Yes -  thumbs up
    Just wanted to make sure that you put in a 40 mA (rather then 40 A) fuse ?
    There' will be a problem in the logic control of the amplifier.
    A bit hard to diagnose "per remote" but if you have a multimeter and a bit of
    electronic knowledge, we can guide you along a bit.
    If you are not sure this is a task for you, I recommend you bring it in for service.
    It doesn't sound like an expensive repair to me. Most likely candidates are rectifier and one or more capacitors.
