Latest post 05-08-2009 8:23 AM by 9 LEE. 4 replies.
Page 1 of 1 (5 items)
  • 01-21-2008 5:51 AM
    Beocenter 9500 connect IPod
    Dear B&O fans,
     Does someone know what cable I need to connect an I-Pod to my Beocenter 9500. Is this possible?
    Thanks in advance & regards,
     Dirk.  .
    Filed under: ,
  • 01-21-2008 5:58 AM In reply to
    Re: Beocenter 9500 connect IPod
    You need a DIN to Minijack lead. Should be available from local hi fi outlets or there are a number for sale on ebay.
    Plug the DIN into the AUX socket on the 9500 and the minijack into the I Pod and away you go!
    Regards Graham
  • 01-21-2008 6:35 AM In reply to
    Thanks for your reply Graham!
  • 05-08-2009 8:04 AM In reply to
    Hello what are the specification of the port din, the din size the number of pin.
    Thanks a lot.
  • 05-08-2009 8:23 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    It's just a 5 Pin Din to 3.5mm jack lead.  Ignore the fact the AUX port on your B&O has 7 pins by the way, the other two aren't needed.
    Our site sponsor Sounds Heavenly sells some high-end B&O to iPod leads - just click on his link at the bottom of the page!
    Lee
