Latest post 02-01-2008 2:42 PM by BEOfreak. 11 replies.
Page 1 of 1 (12 items)
  • 01-20-2008 3:21 PM
    • BEOfreak
    • Not Ranked
    • Joined on 04-17-2007
    • Odense, Denmark
    • Posts 63
    "Hockey Puck" IR Eye Service manual
    I'm looking for a service manual for a hockey puck IR eye.
    I have a broken puck - IR is not working, only buttons.
    Anybody?
    Thanks Rasmus
    Avant CTV 28", V6000, DVD1, BC9000, BS3000, BL4000, MX4200, CX50, BeoCom 2, Beocom 6000, LC1, LC2
    Filed under:
  • 01-20-2008 4:06 PM In reply to
    Re: "Hockey Puck" IR Eye Service manual
    You have checked that it is not set to Option 0? Try L.Opt Number on a beo4 or Link, Number Store on the Beolink 1000.
    I may be able to get hold of the manual, though I am not sure how useful it will be. What device are you using it with? Beolink Active etc?
  • 01-21-2008 1:46 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    It maybe disabled rather than broken, perhaps someone knows how to check.  I didn't know there was a service manual for the IR Eye, if there was one can someone upload it?
    Beoaus
  • 01-21-2008 4:00 AM In reply to
    I would be surprised if the IR is at fault and even if a Service Manual existed which I think is most unlikely, it would not help you, because any faulty part would require the small round board to be replaced. Assuming it was working and you did not change the configuration in any way, then I suggest you test it on another unit (example Beolink Passive) or have it tested at your dealer.
    Regards Keith....
  • 01-21-2008 4:46 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Maybe this helps? (just the cabling...)
     Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-21-2008 12:47 PM In reply to
    • kallasr
    • Posts 1,077
    Having seen comments like this one:
     "Member kallasr should be urged to attach the picture to his message in the Beoworld forum rather than an external link. It would also allow us to keep the info regardless of others websites."
    I just want to let you guys know, that the forum picture attachment DOES NOT WORK with my computer/set-up. And I am sure, I am not the only one with these issues.
    The comment above was deleted by the way....
    Best regards
    Ralf
  • 01-21-2008 2:23 PM In reply to
    Actually I think I have the service manual! Not sure how useful it is but it does have the circuit diagram and pictures of the PCB. I'll see what I can do.
  • 01-21-2008 4:03 PM In reply to
    I have put the service manual for the Beolink Active on - the IR puck is included.
    http://www.beoworld.org/manuals_view.asp?pid=980
  • 01-23-2008 3:10 AM In reply to
    • BEOfreak
    • Not Ranked
    • Odense, Denmark
    • Posts 63
    Thank you all for your replies, and Peter thanks for the Service Manual.
    It's a used puck connected to a used BeoLink Passive. I bought them on two different internet auctions, so they have never worked together before.
    I'll try to change the option at first. Where is the option information stored, in the Puck or in the attached BeoLink unit?
    Thanks again
    Rasmus
  • 01-23-2008 3:25 AM In reply to
    The option information is stored in the device (product) and not in the IR "Hockey Puck" as you call it.
    The IR Receiver/Transmitter receivers the signal and converts it into TTL levels for the attached product plus drivers for the two LED's
    As the "Puck" apparently works for all functions other than the IR, then the problem is likely to be either:-
    • A Faulty IR circuit in the Puck
    • Incorrect option value
    • The "Puck" incorrectly wired to the Din plug which goes into the Beolink Passive.
    Do you have a spare IR receiver you could test the Beolink Passive with ?
    Regards Keith....
  • 01-23-2008 4:46 AM In reply to
    • BEOfreak
    • Not Ranked
    • Odense, Denmark
    • Posts 63
    Thanks for your quick reply Keith!
    I will get back to you with the result, when I have tried to change the option and checked the wiring.
    Unfortunately I don't have a spare IR receiver to test the Beolink Passive with...
    Regards Rasmus
  • 02-01-2008 2:42 PM In reply to
    • BEOfreak
    • Not Ranked
    • Odense, Denmark
    • Posts 63
    It's working!!!
    I changed the option to 6 and it is now revieving ir commands.
    Thanks for all your support...
     Best regards Rasmus
