So he is here again ![Smile](http://forum.beoworld.org/emoticons/emotion-1.gif)
I've managed to find an OSX 86 version which supports all the hardware in my pc.
It's an Aopen, AX4GE Tube with onboard audio (A real TUBE!!), ethernetcontroller and video.
After installing everything seems to work. Mail, Safari, I-Tunes etc, Dashboard. So I am a proud owner of a fake
Mac P4 2,4 Ghz 512 MB etc......
I even installed the BM-Link 1.5 software and it looks like it works, but not 100 %.
I can switch on/off the (power) linkspeakers, adjust the volume and I-Tunes starts after pressing NMusic.
My smile gets even bigger.....![Laughing](http://forum.beoworld.org/emoticons/emotion-61.gif)
But here it comes, several functions won't work. After starting Nmusic from the livingroom, I can see that I-tunes starts up and then BMlink stops ![Tongue Tied](http://forum.beoworld.org/emoticons/emotion-7.gif)
If I start BM-link via the preference panel/BM link, then again it will function again for a while.
The problem, I hope, lies in the firmware update 1.31 I think.
The control panel tells me that I have 1.30 and it will be updated to 1.31.
Then you can see that it makes contact with the PC2. But after a second there is a message :"Can't send data to PC2" (In dutch)
Why? can someone tell me what it can be? Why doesn't the PC2 accepts an 1.31 update?
My neighbour has a real Mac (an oldie I-mac, 400Mhz etc with 10.4.something, but nevertheless), so I have tried it at his place.
After installing I can't update the firmware either. The same response as at my place: you have 1.30 it will be updated to 1.31, update?
"Can't write data to hardware"
It's a bit frustating. I've tried to give it its own USB connection (not shared with keyboard, mouse etc). But it didn't work so far.
Any Ideas? Has someone experienced the same problem?
Any help would be gratefull. Thanks in advance.
Beobuddy.
