Dear GK31AX,
Checked again - no luck I'm afraid. I moved the switch to all positions whilst playing a CD and the same static click every half-second or so. Thanks for you help anyway. Hosky
I would be happy to take a look at this for you if you cannot solve it. I am based in Farnham, Surrey, UK
Regards, Neil
Thank you Neil,
Are you a qualified engineer because it's been suggested that it might be the amplifier inside the speaker. What do you think? Thanks for your interest. By the way I'm in St Ives in Cornwall.
Cheers David
I have seen a similar fault on one occasion and it was the mains relay.
Dealer fix and cost around £50 if I recall.
Regards Graham
It was just over £100 and we had to wait over 2 weeks because B&O didnt have any of the relays in stock.
They charged us £30 just to diagnose it and then a further £70 odd to fix it.
I bet the relay cost them pennies!!
Brett
