Santiago:
355f: Actually the table stand is a large heavy alloy stand that has quite some depth at the rear or the screen
You could look at a Pioneer floor stand- looks very BnO all in alloy- if you wanted to floor rather than table mount
Hi 355f,
BV4 would be over a table for sure (not on floor stand), probably something like this or this... so the table stand depth and size is not a problem at all... but now I'm thinking how to place the BL7.2... and that's more difficult !! I can see that BV4 stay too low, so surely I'll need to put something under the stand to lift it over 10cms and let space enough for the BL7.2
Thats not going to work to well! I have mine on a table stand. problem is that the base of the stand protrudes 3 in in front of the screen and about 8 behind so actually its impossible to mount the speaker in the way you suggest. the speaker protrusion is to great
My solution was to place the BV4 on the table stand on a coffee table with wide marble supports either side and then mount the BL7 under the table- Actually it works ok.
But when the BL10 comes out I will buy the pioneer floor stand and mount the bl10 under the screen as its the same depth
