Latest post 01-19-2008 4:29 PM by Maarten. 3 replies.
Page 1 of 1 (4 items)
  • 01-17-2008 11:03 AM
    iTunes 7.6, BM-Link 1.0 or 1.5
    Anyone try this yet?
  • 01-17-2008 4:12 PM In reply to
    Re: iTunes 7.6, BM-Link 1.0 or 1.5
    Every day I wake up with N.Radio from Apple/Beoport still with software version 1.0
    I had troubles with version 1.5 when this came out as an update. Something to do with my first edition Mac Mini (non-Intel) I think.
    iTunes version = 7.6
    Now there is no need for me anymore to make use of version 1.5
    The frontrow enabler software doesn't support Safari 10.4.11 at the moment.
    Check your playlist on the left in iTunes.
    After installing 7.6 my N.Radio tag was missing. A blank tag was there. I renamed the blank tag to "N.Radio".
  • 01-18-2008 6:08 PM In reply to
    You can easily modify create your own Apple Scripts and use them with BM-Link and control in basicly any appliction on your Mac with your BEO4.
    With a small change to the existing Frontrow script in BM-Link, you can control Frontrow again under Leopard.
  • 01-19-2008 4:29 PM In reply to
    • Maarten
    • Not Ranked
    • Joined on 04-18-2007
    • Wendover
    • Posts 19
    Yep, 7.6 and 1.5 work fine
    Maarten
