I'm wondering if someone knows (or could measure) the dimensions of the column of the BL 1 speaker. I can only find the height and the diameter of the base. The column appears to be (sort of) ellipictical in cross section. This is the measurement I need.
CheersStuart
Hi Stuart,
I just measured mine: 17.2mm from side to side and 14.5mm from front to back. Let me know if you need any other dimensions.
s.
turbotol: Hi Stuart,I just measured mine: 17.2mm from side to side and 14.5mm from front to back. Let me know if you need any other dimensions. s.
I guess you mean cm!
Exactly,
17,2 and 14,5 are in centimeters, and the both straight (flat) sides of the cross section are 8 cms each.
Regards.
Santiago
