Latest post 01-17-2008 6:24 PM by Jandyt. 9 replies.
Page 1 of 1 (10 items)
  • 01-16-2008 11:53 AM
    Audio Aux Link on rear of MX4002
     On the rear of my MX4002 i have a 7pin socket named Audio Aux Link (not shown in manual). I also have one of them Aux to iPod leads.
    Will this work with my macbook, as i have plugged it in, selected A.Aux on the beo4, but no sound. Should this socket work with this lead or not?
    Thanks in advance.
    Never Mind The Ball-Cocks www.markmossplumbing.co.uk
    A labourer uses his hands
    A tradesman uses his hands and his head
    A craftsman uses his hands, his head and his heart
  • 01-16-2008 3:39 PM In reply to
    Re: Audio Aux Link on rear of MX4002
    Anyone?
  • 01-16-2008 3:57 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Don't you have to press AV then A.aux?
    CraigSmile
  • 01-16-2008 3:58 PM In reply to
    For anyone else wanting to know the answer to this:-
    MX4002 Audio Aux Link - unfortunately, the cable will not operate with this connection as it is intended for use with the audio systems only (BS9000 to Mac will work perfectly.) Generally the Audio Aux Link connection is intended for use when combining a B&O TV with an audio system AV integration. This connection contains the signals for control of the equipment in addition to the audio input and output from the systems.
    Cheers
    Mark.
  • 01-17-2008 3:47 PM In reply to
    For the moderators:
    I couldn't get into this post. I had to look for Mark' posts in his personal info tab. After selecting the second post I was able to get through to this post.
    For Mark:
    I too have tried to hook up an Aux connector to my MX4002. As mentioned here before it's not possible to get sound out of the MX4002 speakers. But I have had sound comming out of the speakers. Because I didn't want to make use of this function I disconnected the cable. I'm sorry, but can't remember how I did it make it happen. You have to take my word for it. During testing I have tried a lot of BEO4 settings. One of the settings made it possible to listen to audio on my MX4002.
  • 01-17-2008 5:20 PM In reply to
    According to the service manual AV RADIO opens the Aux Link socket to receive audio.
    Regards Graham
    Hey Coolskin,
     Sounds promising, currently my BL4000's are hooked up to the MX4002 (temporary measure while the lounge is being decorated) so if the solution suddenly pops into your head then let me know.
    Cheers
    Mark.
  • 01-17-2008 5:22 PM In reply to
    Didnt see your post Graham, I'll try it now..
  • 01-17-2008 5:35 PM In reply to
    How do i select AV RADIO? It does not appear under the lists in Beo4, or should i select AV then Go and then RADIO? If so this doesnt appear to work.
  • 01-17-2008 6:24 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Mark, If you have the VMEM type Beo4, add AV to your list then press list til AV comes up, don't press go just press radio.
    Hope that made sense.
    Andy T.
    Poor me, never win owt!
