Dear all,
Sorry to come with a newbie question again...
I know BL9s and BL5s are much better than the BL8000 + subwoofer option, but I love the design of my BL8000s and I am ready to experiment this compromise. So, it appears that most of you recommend the B&W PV1 above the BL2, as it is faster and less boomy (despite that it does not relieve the BL8000 from playing the bass like the BL2 does). Right, let's go for the PV1.
I would use a single PV1, so this one has to process both the left and right channels. For this setup, the audio master would be a Beocenter 9500 (I have a Beosound 9000 in another room, but I don't need a subwoofer there), which has no dedicated subwoofer output. Now, how would I best connect a PV1, which has two input options:
- through the Speaker input (which is stereo and is supposed to be connected to an amplified speaker-level output): it is stereo for sure but (i) it is not the very same line signal as the PowerLink one which feeds the BL8000s (but is it an issue?); and (ii) it requires a double SpeakerLink cable which is thicker (i.e. more visible and less aesthetic) than a PowerLink cable; or
- through the Line input (which I think is mono and is supposed to be connected to a dedicated non-amplified line-level subwoofer output): this solves the issues mentioned above, but how do I mix the left and right signals? Is there any special cable to do that?
Thanks again for your help.
Kind regards,
Jean-Sebastien
