Latest post 01-15-2008 6:50 AM by Daniel. 3 replies.
Page 1 of 1 (4 items)
  • 01-14-2008 4:41 PM
    Linking with Beosound Century
    Hello,
    I'm wondering if it is possible to link a Beosound Century to a MX4000 via 7-pin Datalink cable. Has anybody experience in that?
    Alex.
  • 01-14-2008 5:52 PM In reply to
    Re: Linking with Beosound Century
    You cannot 'link' as the Century has no Datalink. But you should be able to play the sound via Aux. 5 pin DIN is all you need.
  • 01-15-2008 5:26 AM In reply to
    Thanks Peter,
    but does this mean that I can "cable together" Century and MX and then listen the sound played from the Century through the BL8000-speakers connected to the MX. Is this "commanded" by AV-CD (-Radio, etc.)?
    Alex.
  • 01-15-2008 6:50 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    No, aux on Century is input only. Your only chanse is to use the headphone minijack connected to one of the scarts on the MX. I don´t know if this will work. Anyone?
    If it will work you still cant use [AV]. Instead open scart input on MX by pressing whatever you name it to ([SAT] etc.).
    To change station or track you must first press [CD] or [RADIO]. To change volume you must again press [SAT] etc before you adjust the volume.
