Latest post 01-16-2008 4:45 PM by philmw. 15 replies.
Page 1 of 1 (16 items)
  • 01-14-2008 7:47 AM
    • philmw
    • Not Ranked
    • Joined on 06-27-2007
    • Posts 9
    Avant and SKY+
    Is it possible to get a firmware (?) update for my Avant to include SKY+ as a STB option?  Mine only lists Sky Digital, not Sky+
    Thanks in advance.
  • 01-14-2008 7:51 AM In reply to
    Re: Avant and SKY+
    Yes, and it is fantastic! Integrates perfectly both in the main room and in link rooms. Quite frankly, if you have this, I can see no reason to consider the HDR2. If you don't have Sky+ yet, do your best to get a Pace box - by far the best.
  • 01-14-2008 7:55 AM In reply to
    • philmw
    • Not Ranked
    • Posts 9
    Re: Avant and SKY+
    Thanks Peter.  I have only just changed to Sky+ (Amstrad box I'm afraid) (and Sky HD (Thompson) in another room) as I was reluctant to stop using my old Sony decoder.  Sky+ is wonderful though.
     How do I go about changing the firmware?
  • 01-14-2008 8:04 AM In reply to
    Re: Avant and SKY+
    What about TIVO? I really like this, prefer it to Sky+ and was thus considering purchasing it. Can this be worked in the same way?
    Graham
  • 01-14-2008 8:08 AM In reply to
    Re: Avant and SKY+
    I thought that was no longer available in the UK? It is listed in the US STB-C - not sure about the UK.
  • 01-14-2008 8:13 AM In reply to
    Re: Avant and SKY+
    It is not available brand new but you can buy from SchemeBay. It is still supported - you can purchase a lifetime subscription and the servers still run so you can download program info.
    It is also good for modding - there are a few books that tell you how to hack it and you can also add larger hds etc.
  • 01-14-2008 8:51 AM In reply to
    Re: Avant and SKY+
    I don't want to hijack this, but I have a related question: Where can you get hold of the brackets that carry STBs at the back of an Avant?
    I just bought a 28 inch RF VCR Avant this morning, and would like to keep things tidy by trying to get my hands on one these brackets so I can stow my STB neatly away as soon as I get the Avant.
  • 01-14-2008 8:56 AM In reply to
    Re: Avant and SKY+
    From one of the site sponsors!! STB Brackets, and very good they are too!
  • 01-14-2008 9:04 AM In reply to
    Re: Avant and SKY+
    j0hnbarker:
    Also you can get them off of SchemeBay from time to time second hand.I always wanted to know though: If STB is at back of set how does the remote remain in range. Do you have to use an IR extender?
  • 01-14-2008 9:08 AM In reply to
    Re: Avant and SKY+
    That is the point of the STB-C for the Sky+. The TV controls the box through a separate wire with an IR blaster on this. This is how one can use Sky thoughout a link system without being in the main room. That is what I meant by Sky+ integrating with the Avant seamlessly. You would think it was part of the TV.
  • 01-14-2008 9:13 AM In reply to
    Re: Avant and SKY+
    Thanks to you both. The Avant has cleaned me out, so I might have to look on eBay in the first instance I think, unless anyone has one they want to sell???
  • 01-14-2008 9:15 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Avant and SKY+
    Poor Philmw.
    Nobody seems to have answered your question satisfactoraly.
    If you look through your list, you will probably find Pace Sky+, it's number 36 on my list. It will work fine with your box whether it's Amstrad, Thompson or whatever.
    Andy T.
    Poor me, never win owt!
  • 01-14-2008 2:15 PM In reply to
    Re: Avant and SKY+
    I am afraid he probably needs the upgrade. Sky+ is often not listed on Avants.
  • 01-16-2008 2:57 PM In reply to
    • philmw
    • Not Ranked
    • Posts 9
    Re: Avant and SKY+
    Thanks Andy and Peter,
    I only have 6 choices (Selector, Nokia D-Box, Nokia 9602S, Pace DTR730-IM, Philips DTX6370, Sky Digital).  I need an upgrade.  Who do I speak to, and (roughly) how much?
    Thanks all
    Phil
  • 01-16-2008 4:20 PM In reply to
    Re: Avant and SKY+
    Your dealer - and about £60. Worth it!
  • 01-16-2008 4:45 PM In reply to
    • philmw
    • Not Ranked
    • Posts 9
    Re: Avant and SKY+
    Many thanks.
