Latest post 01-13-2008 6:27 AM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 01-13-2008 5:56 AM
    • AdUk
    • Not Ranked
    • Joined on 05-17-2007
    • Posts 26
    Beocenter 7007 remote
    Ho,
    does anyne know if any other remotes will work ths system? I was thinking of possible the Beomaster 8000 remote, or maybe the Beocenter 7000?
     thanks,
    Adam
  • 01-13-2008 6:27 AM In reply to
    Re: Beocenter 7007 remote
    Pretty sure all the 7000 systems use the same codes. The 7700 also uses two way which the 7007 won't. The 7007 is able to use the MCL82 system by the way!
