Latest post 01-19-2008 6:26 PM by Goldfrog88. 15 replies.
Page 1 of 1 (16 items)
  • 01-12-2008 9:02 AM
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    BS3+HDMI - help needed
    Hi all,
    Today I tried the first time to utilise the HDMI connections of the BS3. In the connections menu selections are HDMI A (the first), SOUND INPUT HDMI Instead of nice HD picture and sound I just get a black and white message:
    WARNING
    CONTENT IS PROTECTED
    SELECT ANOTHER SOURCE
    The device is Toshiba HD DVD player and works well with component outputs. In this case connections are defined as HDMI  NO and YPBPr YES.
    What have I done wrong? If I can not use HDMI connections I'll face troubles in the future.
    The BS3 is connected with the normal DVI-D cable to a non B&O Plasma's DVI-D input
  • 01-12-2008 1:58 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: BS3+HDMI - help needed
    I have seen this before on a BS-3.  The HDMI connection can be a bit fiddly, mostly from the software side.  Power the BS-3 down, or put it on another source, poer off the player,  then unplug the HDMI Cable from either end, reconnect it and power up the player and switch the BS-3 back to it.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 01-13-2008 8:28 AM In reply to
    • Mico
    • Finland
    • Posts 136
    Russ, thank for your reply! Unfortunately it did not solve the issue.
    I had some progress, the PCM audio now comes through HDMI but still no picture.
    It seems that there are compatibility issues with the Plasma. The Plasma is three years old, HD Ready but without a HDMI connection. The Plasma can also be used as a Projector, picture is not great with BS3. But even in this case the same error message appears with the DVD player. I connected a computer monitor with DVI to the BS3 and picture was ok (Display one defined as a Projector).
    I have now tried all connections, powered the units up and down in different  order, even with another HDMI cable.
    So, I am puzzled. A simple 200€ lcd monitor works ok but the 3000€ plasma does not. Somehow I would trace the problem to the BS3 because of the error message. I think I will return the DVD Player and try the Playstation 3 (or another Blu-Ray Player.
  • 01-13-2008 11:08 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The issue is with the Plasma screen, not the BeoSystem 3. A technology called HDCP (HD content protection) is starting to be used by manufacturers and film studios. It essentially requires that all components in your system can talk to each other to assure that everything is an 'approved' component and not anything which would allow you to copy the DVD.
    You'll need to change the Plasma panel, or you're going to run into this problem a lot with HD...
     Weekly top artists:
  • 01-13-2008 11:14 AM In reply to
    • 355f
    • Joined on 04-19-2007
    • Posts 655
    Alex:
    HDCP starting to be used?? it was used from the start thats why HDMI was invented!  On some products if you allow this messge to stay on screen for to long it will take out the input board on the connected item
  • 01-13-2008 11:20 AM In reply to
    • Mico
    • Finland
    • Posts 136
    Alex:
    Yes, this what I have been thinking as the cause as well. The thing that is puzzling me is that that I do not get any picture from the DVD player with HDMI. Not even the setup menus. Everything works fine if I use the component output. Based on the manual the HDCP is implemented in the discs, not to everything the player is sending through HDMI. And how does the Computer monitor go around this?
  • 01-13-2008 11:23 AM In reply to
    • Alex
    • Posts 2,990
    355f:
    Alex:
    True, but HDMI is only just starting to become used widespread. So far it's generally been reserved more for early HD adopters...
     Weekly top artists:
    • moxxey
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Alex:
    I think Alex is right. Although you have a DVI socket (like the BV7-32), the BV7 required a HD upgrade to support HDCP. If your TV doesn't support HDCP, you'll hear audio but not receive a video signal. ie. it will be blocked. Some TVs show fuzziness, others show nothing at all.
  • 01-13-2008 11:25 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    355f:
    Yeah, but if you read his post....he has a HDMI -> DVI converter as his plasma is an old DVI-only socket.
    • 355f
    • Posts 655
    Mico:
    Alex:
    Only HDMI carries HDCP not component. With HDCP every component in that chain has to handshake otherwise no picture.
  • 01-13-2008 11:35 AM In reply to
    • Mico
    • Finland
    • Posts 136
    moxxey:
    Alex:
    I am quite certain that my plasma does not have HDCP. With this I need to get in contact with the screen manufacturer. I am currently unwilling to invest on a new screen because of lack of HD sources. My test during the weekend seems to be a failure so farSad.
    BTW The local DVD rental agencies have a VERY limited offering (both in BD and HD DVDs). This might lead to postponing the whole HD project.
  • 01-13-2008 11:37 AM In reply to
    • Mico
    • Finland
    • Posts 136
    355f:
    Mico:
    Alex:
    I understand this but how do the projectors or computer monitors go around this?
  • 01-13-2008 11:38 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    Mico:
    Alex is right over this, too. You can't upgrade an old run-of-the-mill TV to support HDCP. If you could, you'd have to pay a fair few hundred pounds and, considering most 42" plasmas are around £1000 these days, it wouldn't be worth doing this - you'd be better off getting a new plasma!
  • 01-13-2008 11:50 AM In reply to
    • 355f
    • Posts 655
    Mico:
    355f:
    Mico:
    Alex:
    any procust that have HDMI will contain the HDCP
    The difrerence is that some manufacturers use a chip set for HDCP that is very 'open to interpretation' about what hdcp is! and this means that actually you an connect most things and they work!
    Rather frustratingly, you tend to find that the cheaper products allow content to be played. Hence the reason why one gets the comment that some crappy £40 player works but my $4000 BnO doesnot!
  • 01-13-2008 11:56 AM In reply to
    • Mico
    • Finland
    • Posts 136
    355f:
    Mico:
    355f:
    Mico:
    Alex:
    Bulls eye!
  • 01-19-2008 6:26 PM In reply to
    • Goldfrog88
    • Joined on 06-07-2007
    • Melbourne, Australia
    • Posts 83
    • Gold Member
    This is great info guys. I've just found the problem after upgrading the software on BS3. Looks like I'll need an HDMI-compliant monitor; my Full-HD Sharp AQUOS panel (of three years) only supports a DVI connection! But there's a thin silver lining to this cloud, if you accidentally set your panel to a res it can't show, you can always connect a computer monitor to the BS3 to see the menu and 'undo' the selection --- provided you're not in Full HD mode 'only' (as most small computer monitors don't support 1920 by 1280).
